#error "ADVANCED_PAUSE_FEATURE requires NOZZLE_PARK_FEATURE." Marlin 1.1.9
Собираю прошивку 1.1.9 (Сейчас использую Модифицированную заводскую 1.1.6)
Получаю ошибку SanityCheck.h #error "ADVANCED_PAUSE_FEATURE requires NOZZLE_PARK_FEATURE."
В SanityCheck.h есть проверка
* Advanced Pause
#if ENABLED(ADVANCED_PAUSE_FEATURE)
#if !HAS_RESUME_CONTINUE
#error "ADVANCED_PAUSE_FEATURE currently requires an LCD controller or EMERGENCY_PARSER."
#elif ENABLED(EXTRUDER_RUNOUT_PREVENT)
#error "EXTRUDER_RUNOUT_PREVENT is incompatible with ADVANCED_PAUSE_FEATURE."
#elif ENABLED(PARK_HEAD_ON_PAUSE) && DISABLED(SDSUPPORT) && DISABLED(NEWPANEL) && DISABLED(EMERGENCY_PARSER)
#error "PARK_HEAD_ON_PAUSE requires SDSUPPORT, EMERGENCY_PARSER, or an LCD controller."
#elif ENABLED(HOME_BEFORE_FILAMENT_CHANGE) && DISABLED(PAUSE_PARK_NO_STEPPER_TIMEOUT)
#error "HOME_BEFORE_FILAMENT_CHANGE requires PAUSE_PARK_NO_STEPPER_TIMEOUT."
#elif DISABLED(NOZZLE_PARK_FEATURE)
#elif ENABLED(PREVENT_LENGTHY_EXTRUDE) && FILAMENT_CHANGE_UNLOAD_LENGTH > EXTRUDE_MAXLENGTH
#error "FILAMENT_CHANGE_UNLOAD_LENGTH must be less than or equal to EXTRUDE_MAXLENGTH."
#elif ENABLED(PREVENT_LENGTHY_EXTRUDE) && FILAMENT_CHANGE_SLOW_LOAD_LENGTH > EXTRUDE_MAXLENGTH
#error "FILAMENT_CHANGE_SLOW_LOAD_LENGTH must be less than or equal to EXTRUDE_MAXLENGTH."
#elif ENABLED(PREVENT_LENGTHY_EXTRUDE) && FILAMENT_CHANGE_FAST_LOAD_LENGTH > EXTRUDE_MAXLENGTH
#error "FILAMENT_CHANGE_FAST_LOAD_LENGTH must be less than or equal to EXTRUDE_MAXLENGTH."
#endif
#endif
В файле Configuration.h
#define NOZZLE_PARK_FEATURE
#if ENABLED(NOZZLE_PARK_FEATURE)
// Specify a park position as { X, Y, Z }
#define NOZZLE_PARK_POINT { (X_MIN_POS + 10), (Y_MAX_POS - 10), 20 }
#define NOZZLE_PARK_XY_FEEDRATE 100 // X and Y axes feedrate in mm/s (also used for delta printers Z axis)
#define NOZZLE_PARK_Z_FEEDRATE 5 // Z axis feedrate in mm/s (not used for delta printers)
#endif
В файле Configuration_adv.h
#define ADVANCED_PAUSE_FEATURE
#define PAUSE_PARK_RETRACT_FEEDRATE 5 // (mm/s) Initial retract feedrate.
#define PAUSE_PARK_RETRACT_LENGTH 10 // (mm) Initial retract.
// This short retract is done immediately, before parking the nozzle.
#define FILAMENT_CHANGE_UNLOAD_FEEDRATE 40 // (mm/s) Unload filament feedrate. This can be pretty fast.
#define FILAMENT_CHANGE_UNLOAD_ACCEL 25 // (mm/s^2) Lower acceleration may allow a faster feedrate.
#define FILAMENT_CHANGE_UNLOAD_LENGTH 400 // (mm) The length of filament for a complete unload.
// For Bowden, the full length of the tube and nozzle.
// For direct drive, the full length of the nozzle.
// Set to 0 for manual unloading.
#define FILAMENT_CHANGE_SLOW_LOAD_FEEDRATE 10 // (mm/s) Slow move when starting load.
#define FILAMENT_CHANGE_SLOW_LOAD_LENGTH 10 // (mm) Slow length, to allow time to insert material.
// 0 to disable start loading and skip to fast load only
#define FILAMENT_CHANGE_FAST_LOAD_FEEDRATE 40 // (mm/s) Load filament feedrate. This can be pretty fast.
#define FILAMENT_CHANGE_FAST_LOAD_ACCEL 25 // (mm/s^2) Lower acceleration may allow a faster feedrate.
#define FILAMENT_CHANGE_FAST_LOAD_LENGTH 10 // (mm) Load length of filament, from extruder gear to nozzle.
//#define ADVANCED_PAUSE_CONTINUOUS_PURGE // Purge continuously up to the purge length until interrupted.
#define ADVANCED_PAUSE_PURGE_FEEDRATE 5 // (mm/s) Extrude feedrate (after loading). Should be slower than load feedrate.
#define ADVANCED_PAUSE_PURGE_LENGTH 50 // (mm) Length to extrude after loading.
// Set to 0 for manual extrusion.
// Filament can be extruded repeatedly from the Filament Change menu
// until extrusion is consistent, and to purge old filament.
// Filament Unload does a Retract, Delay, and Purge first:
#define FILAMENT_UNLOAD_RETRACT_LENGTH 13 // (mm) Unload initial retract length.
#define FILAMENT_UNLOAD_DELAY 5000 // (ms) Delay for the filament to cool after retract.
#define FILAMENT_UNLOAD_PURGE_LENGTH 8 // (mm) An unretract is done, then this length is purged.
#define PAUSE_PARK_NOZZLE_TIMEOUT 60 // (seconds) Time limit before the nozzle is turned off for safety.
#define FILAMENT_CHANGE_ALERT_BEEPS 3 // Number of alert beeps to play when a response is needed.
#define PAUSE_PARK_NO_STEPPER_TIMEOUT // Enable for XYZ steppers to stay powered on during filament change.
#define PARK_HEAD_ON_PAUSE // Park the nozzle during pause and filament change.
#define HOME_BEFORE_FILAMENT_CHANGE // Ensure homing has been completed prior to parking for filament change
//#define FILAMENT_LOAD_UNLOAD_GCODES // Add M701/M702 Load/Unload G-codes, plus Load/Unload in the LCD Prepare menu.
//#define FILAMENT_UNLOAD_ALL_EXTRUDERS // Allow M702 to unload all extruders above a minimum target temp (as set by M302)
#endif
Шестерня vs зубчатое колесо
Недавн...
Круть. Я б вздрогнул такой мас...
В принципе, если ТВаД на взлет...
А вот хамить у нас не принято....
Добрый день! Не знаю куда...
