Klipper ошибка Move out of range
Решил поставить датчик клон bltouch
все настроил, но при калибровке показывает ошибку Move out of range: 18.000 230.500 5.000 [0.000]
Принтер ender 3, прошивка klipper
файл printer.cfg
# This file contains common pin mappings for the BIGTREETECH SKR mini
# E3 v3.0. To use this config, the firmware should be compiled for the
# STM32G0B1 with a "8KiB bootloader" and USB communication.
# The "make flash" command does not work on the SKR mini E3. Instead,
# after running "make", copy the generated "out/klipper.bin" file to a
# file named "firmware.bin" on an SD card and then restart the SKR
# mini E3 with that SD card.
# See docs/Config_Reference.md for a description of parameters.
[include mainsail.cfg]
[stepper_x]
step_pin: PB13
dir_pin: !PB12
enable_pin: !PB14
microsteps: 16
rotation_distance: 40
endstop_pin: ^PC0
position_endstop: 0
position_max: 247
position_min: -2
homing_speed: 50
[tmc2209 stepper_x]
uart_pin: PC11
tx_pin: PC10
uart_address: 0
run_current: 0.580
stealthchop_threshold: 999999
[stepper_y]
step_pin: PB10
dir_pin: !PB2
enable_pin: !PB11
microsteps: 16
endstop_pin: ^PC1
position_endstop: 0
position_max: 225
position_min: -6
homing_speed: 50
[tmc2209 stepper_y]
uart_pin: PC11
tx_pin: PC10
uart_address: 2
run_current: 0.580
[stepper_z]
step_pin: PB0
dir_pin: PC5
enable_pin: !PB1
microsteps: 16
rotation_distance: 8
endstop_pin: probe:z_virtual_endstop
#position_endstop: 0.0
position_max: 250
position_min: -5
[tmc2209 stepper_z]
uart_pin: PC11
tx_pin: PC10
uart_address: 1
run_current: 0.580
[extruder]
step_pin: PB3
dir_pin: !PB4
enable_pin: !PD1
microsteps: 16
rotation_distance: 7.510
full_steps_per_rotation: 200
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PC8
sensor_type: EPCOS 100K B57560G104F
sensor_pin: PA0
control: pid
pid_Kp: 21.527
pid_Ki: 1.063
pid_Kd: 108.982
min_temp: 0
max_temp: 250
max_extrude_only_distance: 100
[tmc2209 extruder]
uart_pin: PC11
tx_pin: PC10
uart_address: 3
run_current: 0.650
[heater_bed]
heater_pin: PC9
sensor_type: ATC Semitec 104GT-2
sensor_pin: PC4
control: pid
pid_Kp: 54.027
pid_Ki: 0.770
pid_Kd: 948.182
min_temp: 0
max_temp: 130
[heater_fan heatbreak_cooling_fan]
pin: PC7
[heater_fan controller_fan]
pin: PB15
[fan]
pin: PC6
[mcu]
serial: /dev/serial/by-id/usb-Klipper_stm32g0b1xx_2800290019504B5735313920-if00
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 700
max_z_velocity: 5
max_z_accel: 100
[input_shaper]
shaper_type_x = ei
shaper_freq_x = 71.1
shaper_type_y = ei
shaper_freq_y = 73.5
[firmware_retraction]
retract_length: 1.0
retract_speed: 30.0
unretract_extra_length: 0
unretract_speed: 30.0
[board_pins]
aliases:
# EXP1 header
EXP1_1=PB5, EXP1_3=PA9, EXP1_5=PA10, EXP1_7=PB8, EXP1_9=,
EXP1_2=PA15, EXP1_4=, EXP1_6=PB9, EXP1_8=PD6, EXP1_10=
# See the sample-lcd.cfg file for definitions of common LCD displays.
[display]
lcd_type: emulated_st7920
spi_software_miso_pin: PD8 # status led, Virtual MISO
spi_software_mosi_pin: PD6
spi_software_sclk_pin: PB9
en_pin: PB8
encoder_pins: ^PA10, ^PA9
click_pin: ^!PA15
[output_pin beeper]
pin: PB5
## EXTRA SETTINGS ##
[safe_z_home]
home_xy_position: 117.5,117.5 # Change coordinates to the center of your print bed
speed: 100
z_hop: 10 # Move up 10mm
z_hop_speed: 5
[bltouch]
sensor_pin: ^PC14
control_pin: PA1
x_offset: -4
y_offset: -45.5
z_offset: 2.2 # Uncomment if starting fresh; Distance should be enough to keep the z-offset positive.
speed: 3.0
samples: 2
samples_result: median
sample_retract_dist: 6.0
samples_tolerance: 0.01
samples_tolerance_retries: 3
# Bed Leveling: https://www.klipper3d.org/Bed_Level.html#determining-thermal-expansion
[bed_mesh]
speed: 120
horizontal_move_z: 5
mesh_min: 14,14.5
mesh_max: 214,185 # Make sure X,Y here meets these conditions (X+(bltouch+x_offset)
Спасибо, что прочитали. Похоже...
Приветствую! Приобрел себ...
