Klipper [verify_heater heater_config_name]
Здравствуйте хочу увеличить время на срабатывание защиты стола а то он не успевает нагреваться вычитал эту команду
max_error: 130
но почему то прошивка выбивает что неверно
Вот весь конфиг
# This file serves as documentation for config parameters of corexy
# style printers. One may copy and edit this file to configure a new
# corexy printer. Only parameters unique to corexy printers are
# described here - see the 'example.cfg' file for description of
# common config parameters.
# DO NOT COPY THIS FILE WITHOUT CAREFULLY READING AND UPDATING IT
# FIRST. Incorrectly configured parameters may cause damage.
# The stepper_x section is used to describe the X axis as well as the
# stepper controlling the X+Y movement.
[stepper_x]
step_pin: ar54
dir_pin: ar55
enable_pin: !ar38
step_distance: .0062
endstop_pin: ^ar3
position_endstop: 222
position_min: 0
position_max: 222
homing_speed: 50
second_homing_speed: 10
# The stepper_y section is used to describe the Y axis as well as the
# stepper controlling the X-Y movement.
[stepper_y]
step_pin: ar60
dir_pin: ar61
enable_pin: !ar56
endstop_pin: ^!ar14
position_endstop: 232
position_min: 0
position_max: 232
homing_speed: 50
[stepper_z]
step_pin: ar46
dir_pin: !ar48
enable_pin: !ar62
step_distance: .0012
endstop_pin: !ar18
position_endstop: 234
position_min: 0
position_max: 234
homing_speed: 10
second_homing_speed: 5
[extruder]
step_pin: ar26
dir_pin: ar28
enable_pin: !ar24
step_distance: .004878
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: ar10
#sensor_type: NTC 100K beta 3950
sensor_type: EPCOS 100K B57560G104F
sensor_pin: analog13
control: pid
pid_Kp: 25.216
pid_Ki: 1.324
pid_Kd: 120.092
min_extrude_temp: 50
min_temp: 5
max_temp: 295
max_extrude_only_velocity: 40
max_extrude_only_accel: 10000
pressure_advance: 0.8
pressure_advance_lookahead_time: 0.002
[heater_bed]
heater_pin: ar8
sensor_pin: analog14
control: pid
pid_Kp: 73.502
pid_Ki: 1.536
pid_Kd: 879.262
min_temp: 0
max_temp: 130
[fan]
pin: ar9
[mcu]
serial: /dev/ttyUSB0
pin_map: arduino
[printer]
kinematics: corexy
# This option must be 'corexy' for corexy printers.
max_velocity: 200
max_accel: 2000
max_z_velocity: 15
max_z_accel: 50
square_corner_velocity: 15
# 'RepRapDiscount 128x64 Full Graphic Smart Controller' type displays
[display]
lcd_type: st7920
cs_pin: ar16
sclk_pin: ar23
sid_pin: ar17
encoder_pins: ^ar31, ^ar33
click_pin: ^!ar35
kill_pin: ^!ar41
max_error: 130
max_error: 130
Вот весь конфиг
[stepper_x]
step_pin: ar54
dir_pin: ar55
enable_pin: !ar38
endstop_pin: ^ar3
position_min: 0
position_max: 222
homing_speed: 50
[stepper_y]
step_pin: ar60
dir_pin: ar61
enable_pin: !ar56
endstop_pin: ^!ar14
position_min: 0
position_max: 232
homing_speed: 50
[stepper_z]
step_pin: ar46
dir_pin: !ar48
enable_pin: !ar62
endstop_pin: !ar18
position_min: 0
position_max: 234
homing_speed: 10
[extruder]
step_pin: ar26
dir_pin: ar28
enable_pin: !ar24
heater_pin: ar10
control: pid
pid_Kp: 25.216
pid_Ki: 1.324
pid_Kd: 120.092
min_temp: 5
max_temp: 295
[heater_bed]
heater_pin: ar8
control: pid
pid_Kp: 73.502
pid_Ki: 1.536
pid_Kd: 879.262
min_temp: 0
max_temp: 130
[fan]
pin: ar9
[mcu]
pin_map: arduino
[printer]
kinematics: corexy
max_velocity: 200
max_accel: 2000
max_z_velocity: 15
max_z_accel: 50
[display]
lcd_type: st7920
cs_pin: ar16
sclk_pin: ar23
sid_pin: ar17
click_pin: ^!ar35
kill_pin: ^!ar41
max_error: 130
замучался с принеров собственой сборки
всем привет, замучался с принеров собственой сборки
история простая: принер core xy, печатает все замечательно, но вот не могу никак...
2 на одной оси.
И так, все еще мучаюсь со своим проектом. Надо завести 2 мотора на Y и один драйвер, подключал перорально, гудят и не едут, подключил посл...
помогите выбрать 3Д принтер
не в датчике дело а в работе д...
Очень загадочно.
Нуууу.... Мы же понимаем, что....
Подскажите кто что сможет имен...
всем привет появилась проблема...
У меня на работе стоит Ultimak...
Печатаю детальку как на фото....
