MKS Sbase + BLtouch, как начать печатать ?
Приветсвую.
Приобрел себе Bltouch, подключил согласно схемам в инете к плате. Работает, команды выполняет.
В конфиге прописал
switch.servo.enable true
switch.servo.input_on_command M280 S3.0 # M280 S7.5 Would be midway
switch.servo.input_off_command M280 S7.0 # Same as M280 S0 0% duty cycle, effectivley off
switch.servo.output_pin 1.23 # Must be a PWM capable pin
switch.servo.output_type hwpwm # H/W PWM output settable
switch.servo.pwm_period_ms 20 # Set Period to 20ms (50Hz) - Default is 50Hz
## Z-probe
# See httpsmoothieware.orgzprobe
zprobe.enable true # Set to true to enable a zprobe
zprobe.probe_pin 1.29 # Pin probe is attached to, if NC remove the !
zprobe.slow_feedrate 5 # Mmsec probe feed rate
#zprobe.debounce_count 100 # Set if noisy
zprobe.fast_feedrate 100 # Move feedrate mmsec
zprobe.probe_height 5 # How much above bed to start probe
Начальный G-Code
G28 X0 Y0
G4 P1000 ; wait 1 second for power to stabalise
G1 Z15 ; move up 25mm to ensure room to drop probe
M280 S3 ; probe down
G32 ; run Z probe (finish height is set in config file)
M500
M280 S7 ; probe arm up
G92 Z18.2 ; set Z (probe offset (11.2) plus probe finish height)
G4 P1000 ; wait 1 second (see comment below)
M280 S0 ; probe servo off <<< if this immediately follows M280 S12 the servos switches off before the probe retract has finished
M190 S220 ; set extruder temp, no wait
G1 X150 Y150 ; move 150mm along the front edge
G1 Z0 ; drop nozzle to prevent ooze
M109 S220 ; set extruder temp and wait
G28 X0 Y0
M117 Printing...
;LAYER_COUNT:100
;LAYER:0
M107
G0 F3600 X140.898 Y113.138 Z0.2
И на строке G1 Z0 сопло благополучно упирается в стол. Что я делаю не так ?
В конфиге прописал
## Z-probe
Начальный G-Code
G28 X0 Y0
M500
G28 X0 Y0
M117 Printing...
;LAYER_COUNT:100
;LAYER:0
M107
