Klipper ошибка Move out of range: 0.600 420.000 2.900 [1408.090]
Доброго времени суток
периодически сталкиваюсь с ошибкой Move out of range: 0.600 420.000 2.900 [1408.090]
принтер кфг
# This file contains pin mappings for the stock 2020 Creality Ender 3
# Pro with the 32-bit Creality 4.2.2 board. To use this config, during
# "make menuconfig" select the STM32F103 with a "28KiB bootloader" and
# serial (on USART1 PA10/PA9) communication.
# It should be noted that newer variations of this printer shipping in
# 2022 may have GD32F103 chips installed and not STM32F103. You may
# have to inspect the mainboard to ascertain which one you have. If it
# is the GD32F103 then please select Disable SWD at startup in the
# "make menuconfig" along with the same settings for STM32F103.
# If you prefer a direct serial connection, in "make menuconfig"
# select "Enable extra low-level configuration options" and select
# serial (on USART3 PB11/PB10), which is broken out on the 10 pin IDC
# cable used for the LCD module as follows:
# 3: Tx, 4: Rx, 9: GND, 10: VCC
# Flash this firmware by copying "out/klipper.bin" to a SD card and
# turning on the printer with the card inserted. The firmware
# filename must end in ".bin" and must not match the last filename
# that was flashed.
# See docs/Config_Reference.md for a description of parameters.
[stepper_x]
step_pin: PC2
dir_pin: PB9
enable_pin: !PC3
microsteps: 16
rotation_distance: 40
endstop_pin: ^PA5
position_endstop: 0
position_max: 235
homing_speed: 50
[stepper_y]
step_pin: PB8
dir_pin: PB7
enable_pin: !PC3
microsteps: 16
endstop_pin: ^PA6
position_endstop: 0
position_max: 235
homing_speed: 50
[stepper_z]
step_pin: PB6
dir_pin: !PB5
enable_pin: !PC3
microsteps: 16
rotation_distance: 8
endstop_pin: ^PA7
position_endstop: 0.0
position_max: 250
[extruder]
max_extrude_only_distance: 105.0
step_pin: PB4
dir_pin: PB3
enable_pin: !PC3
microsteps: 16
rotation_distance: 34.406
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PA1
sensor_type: EPCOS 100K B57560G104F
sensor_pin: PC5
#control: pid
# tuned for stock hardware with 200 degree Celsius target
#pid_Kp: 21.527
#pid_Ki: 1.063
#pid_Kd: 108.982
min_temp: 0
max_temp: 255
pressure_advance:1.000
[heater_bed]
heater_pin: PA2
sensor_pin: PC4
#control: pid
# tuned for stock hardware with 50 degree Celsius target
#pid_Kp: 54.027
#pid_Ki: 0.770
#pid_Kd: 948.182
min_temp: 0
max_temp: 130
[fan]
pin: PA0
[mcu]
serial: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
restart_method: command
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 3000
max_z_velocity: 5
max_z_accel: 100
# Pin mappings for BL_T port
#[bltouch]
#sensor_pin: ^PB1
#control_pin: PB0
[display]
lcd_type: st7920
cs_pin: PB12
sclk_pin: PB13
sid_pin: PB15
encoder_pins: ^PB14, ^PB10
click_pin: ^!PB2
[virtual_sdcard]
path: ~/gcode_files
[pause_resume]
[display_status]
[include mainsail.cfg]
[gcode_macro PAUSE]
rename_existing: BASE_PAUSE
gcode:
{% set E = params.E|default(1.7)|float %}
{% set x_park = printer.toolhead.axis_maximum.x|float - 5.0 %}
{% set y_park = printer.toolhead.axis_maximum.y|float - 5.0 %}
{% set max_z = printer.toolhead.axis_maximum.z|float %}
{% set act_z = printer.toolhead.position.z|float %}
{% if act_z
#*# DO NOT EDIT THIS BLOCK OR BELOW. The contents are auto-generated.
#*# [heater_bed]
#*# control = pid
#*# pid_kp = 75.627
#*# pid_ki = 1.888
#*# pid_kd = 757.215
#*# [extruder]
#*# control = pid
#*# pid_kp = 27.954
#*# pid_ki = 1.467
#*# pid_kd = 133.131
Ошибка периодическая подскажите куда копать?
Проблема:
Пр...
Все отлично сделано,но есть од...
А Вы не измеряли потребляемую....
Приветствую! Приобрел себ...
