Как правильно ставить автокалибровку перед печатью Klipper?
Crea
4838
10
Всем привет. Ставлю в начале gcode после
G28
BED_MESH_CALIBRATE
промеряет стол, но потом никуда не едет и пишет:
Move out of range: -0.001 254.963 -0.089 [-2.000]
и естественно отмена печати.. Вот что ему бесу нужно?
[printer]
kinematics: corexy
max_velocity: 10000
max_accel: 4000
max_z_velocity: 3
max_z_accel: 230
[stepper_x]
step_pin: PF13
dir_pin: !PF12
enable_pin: !PF14
microsteps: 256
rotation_distance: 36
endstop_pin: !PG14
position_endstop: 0
position_max: 305
homing_speed: 20
[tmc2208 stepper_x]
uart_pin: PC4
run_current: 1.1
hold_current: 0.4
stealthchop_threshold: 999999
[stepper_y]
step_pin: PG0
dir_pin: !PG1
enable_pin: !PF15
microsteps: 256
endstop_pin: !PG15 # endstop have'!' is NO
#position_min: 0
position_endstop:0
position_max: 305
homing_speed: 20
[tmc2208 stepper_y]
uart_pin: PD11
run_current: 1.1
hold_current: 0.4
[stepper_z]
step_pin: PF11
dir_pin: !PG3
enable_pin: !PG5
microsteps: 256
rotation_distance: 1.2
endstop_pin: PG12 # endstop have'!' is NO
position_endstop: 439.68
step_pulse_duration: 0.0000001
position_max: 439.68
homing_speed: 3
second_homing_speed:3
[tmc2208 stepper_z]
uart_pin: PC6
run_current: 2.0
hold_current: 0.5
#interpolate: True
[extruder]
step_pin: PE6
dir_pin: !PA14
enable_pin: !PE0
microsteps: 16
rotation_distance: 25
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PA2
sensor_type: ATC Semitec 104NT-4-R025H42G
sensor_pin: PF5
#control: pid
#pid_Kp: 22
#pid_Ki: 1.08
#pid_Kd: 114
min_temp: 0
max_temp: 260
max_extrude_cross_section: 0.8 # если ругается, увеличить
#min_extrude_temp: 170
pressure_advance: 0.1425
[tmc2208 extruder]
uart_pin: PD3
run_current: 0.8
hold_current: 0.4
sense_resistor: 0.110
[probe]
pin: !PC5
z_offset: 1.2 #0.79
[bed_mesh]
speed: 100
horizontal_move_z: 5
mesh_min: 10, 10
mesh_max: 290, 290
probe_count: 3, 3
