Проблема с настройкой автоуровня стола под индукционный датчик
Не нашел нормальной инструкции, делал по тому что нашел. В итоге
Marlin 1.6.0 ругается
Прошу помочь
In file included from MarlinConfig.h:39:0,
from Marlin.h:36,
from blinkm.cpp:28:
SanityCheck.h:353:6: error: #error 'AUTO_BED_LEVELING_FEATURE requires a probe! Define a Z Servo, Z_PROBE_ALLEN_KEY, Z_PROBE_SLED, or FIX_MOUNTED_PROBE.'
from Marlin.h:36,
from blinkm.cpp:28:
SanityCheck.h:400:10: error: #error 'FRONT_PROBE_BED_POSITION must be less than BACK_PROBE_BED_POSITION.'
Ошибка компиляции.
Кусок прошивки
//============================ Bed Auto Leveling ============================
// @section bedlevel
#define AUTO_BED_LEVELING_FEATURE // Delete the comment to enable (remove // at the start of the line)
// Enable this feature to get detailed logging of G28, G29, M48, etc.
// Logging is off by default. Enable this logging feature with 'M111 S32'.
// NOTE: Requires a huge amount of PROGMEM.
//#define DEBUG_LEVELING_FEATURE
#if ENABLED(AUTO_BED_LEVELING_FEATURE)
// There are 2 different ways to specify probing locations:
// - 'grid' mode
// Probe several points in a rectangular grid.
// You specify the rectangle and the density of sample points.
// This mode is preferred because there are more measurements.
// - '3-point' mode
// Probe 3 arbitrary points on the bed (that aren't collinear)
// You specify the XY coordinates of all 3 points.
// Enable this to sample the bed in a grid (least squares solution).
// Note: this feature generates 10KB extra code size.
#define AUTO_BED_LEVELING_GRID
#if ENABLED(AUTO_BED_LEVELING_GRID)
#define LEFT_PROBE_BED_POSITION 30
#define RIGHT_PROBE_BED_POSITION 140
#define FRONT_PROBE_BED_POSITION 140
#define BACK_PROBE_BED_POSITION 30
#define MIN_PROBE_EDGE 10 // The Z probe minimum square sides can be no smaller than this.
// Set the number of grid points per dimension.
// You probably don't need more than 3 (squared=9).
#define AUTO_BED_LEVELING_GRID_POINTS 2
#else !AUTO_BED_LEVELING_GRID
// Arbitrary points to probe.
// A simple cross-product is used to estimate the plane of the bed.
#define ABL_PROBE_PT_1_X 0
#define ABL_PROBE_PT_1_Y 25
#define ABL_PROBE_PT_2_X 0
#define ABL_PROBE_PT_2_Y 140
#define ABL_PROBE_PT_3_X 140
#define ABL_PROBE_PT_3_Y 30
#endif !AUTO_BED_LEVELING_GRID
#define Z_PROBE_END_SCRIPT 'G1 Z10 F12000
G1 X15 Y330
G1 Z0.5
G1 Z10' // These commands will be executed in the end of G29 routine.
// Useful to retract a deployable Z probe.
// If you've enabled AUTO_BED_LEVELING_FEATURE and are using the Z Probe for Z Homing,
// it is highly recommended you also enable Z_SAFE_HOMING below!
#endif // AUTO_BED_LEVELING_FEATURE
// @section homing
// The center of the bed is at (X=0, Y=0)
//#define BED_CENTER_AT_0_0
// Manually set the home position. Leave these undefined for automatic settings.
// For DELTA this is the top-center of the Cartesian print volume.
//#define MANUAL_X_HOME_POS 0
//#define MANUAL_Y_HOME_POS 0
//#define MANUAL_Z_HOME_POS 0 // Distance between the nozzle to printbed after homing
// Use 'Z Safe Homing' to avoid homing with a Z probe outside the bed area.
// With this feature enabled:
// - Allow Z homing only after X and Y homing AND stepper drivers still enabled.
// - If stepper drivers time out, it will need X and Y homing again before Z homing.
// - Move the Z probe (or nozzle) to a defined XY point before Z Homing when homing all axes (G28).
// - Prevent Z homing when the Z probe is outside bed area.
//#define Z_SAFE_HOMING
Прошу помочь
from Marlin.h:36,
from blinkm.cpp:28:
from Marlin.h:36,
from blinkm.cpp:28:
Ошибка компиляции.
Кусок прошивки
// - 'grid' mode
// - '3-point' mode
G1 X15 Y330
G1 Z0.5
// @section homing
Как сделать мягкий TPU
Пр...
Пр...
Добавил файлы c g-code и 3mf д...
Непонятно - это хорошая новост...
Я, конечно, понимаю - реклама,...
Закончил работу над паг...
