Помогите пожалуйста с с прошивкой.
Достался мне Анет а8 без платы. Купил под него Arduino Mega 2560, RAMPS 1.4 4*A4988. Все собрал, токи выставил. Хотел прошить, но Arduini IDE выдает ошибку.
(экран не покупал)Хочу печатать через провод.
подскажите что делать ?
большое спасибо
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Плата:'Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)'
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Speaker.cpp: In member function 'void Adafruit_CPlay_Speaker::playSound(const uint8_t*, uint32_t, uint16_t, boolean)':
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Speaker.cpp:93:5: error: 'PLLFRQ' was not declared in this scope
PLLFRQ = (PLLFRQ & 0xCF) | 0x30; // Route PLL to async clk
In file included from c:program fileswindowsappsarduinollc.arduinoide_1.8.21.0_x86__mdqgnx93n4wtthardware oolsavravrincludeavrio.h:99:0,
from c:program fileswindowsappsarduinollc.arduinoide_1.8.21.0_x86__mdqgnx93n4wtthardware oolsavravrincludeavrpgmspace.h:90,
from C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtthardwarearduinoavrcoresarduino/Arduino.h:28,
from C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Speaker.cpp:4:
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Speaker.cpp:94:33: error: 'PWM4A' was not declared in this scope
TCCR4A = _BV(COM4A0) | _BV(PWM4A); // Clear on match, PWMA on
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Speaker.cpp:95:19: error: 'PWM4X' was not declared in this scope
TCCR4B = _BV(PWM4X) |_BV(CS40); // PWM invert, 1:1 prescale
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Speaker.cpp:96:5: error: 'TCCR4D' was not declared in this scope
TCCR4D = 0; // Fast PWM mode
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Speaker.cpp:97:5: error: 'TCCR4E' was not declared in this scope
TCCR4E = 0; // Not enhanced mode
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Speaker.cpp:98:5: error: 'TC4H' was not declared in this scope
TC4H = 0; // Not 10-bit mode
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Speaker.cpp:99:5: error: 'DT4' was not declared in this scope
DT4 = 0; // No dead time
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Mic.cpp: In member function 'void Adafruit_CPlay_Mic::capture(int16_t*, uint16_t)':
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Mic.cpp:68:37: error: 'analogPinToChannel' was not declared in this scope
channel = analogPinToChannel(4); // Pin A4 to ADC channel
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:344:3: error: #error 'CPU SPEED NOT SUPPORTED'
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.28e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
static const uint8_t PROGMEM _sineTable[] = { _S3_ _S3_ _S3_ _S3_ }; // 256
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.31129013e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.34256134e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.37379471e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.40497177e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.43607361e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.4670813e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.49797638e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.52874008e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.55935394e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.5897998e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.62005875e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.65011292e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.67994415e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.70953461e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.73886612e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.76792145e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.79668274e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.82513275e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.85325439e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.88103073e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.90844528e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.93548096e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.96212204e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.98835205e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.01415558e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.0395166e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.06442032e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.08885147e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.11279541e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.13623764e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
exit status 1
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.15916428e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.18156128e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.20341507e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.22471283e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.24544128e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.26558838e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.2851416e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.30408951e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.3224205e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.34012375e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.35718842e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.37360413e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.38936081e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.40444962e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.41886093e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.43258636e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.44561752e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.45794632e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.46956589e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.4804686e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.4906485e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.50009903e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.50881454e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.51678986e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.52402008e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.5305014e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.53622894e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.5412001e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.54541138e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.54886047e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.55154526e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.5534642e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.55461609e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.555e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.53050125e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.50009888e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.44561737e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.38936096e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.37360397e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.35718826e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.3401236e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.28514145e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.22471268e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.20341492e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.15916412e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.13623749e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.08885132e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.06442017e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.0395163e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.01415543e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.9883519e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.96212173e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.90844513e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.85325455e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.79668259e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.76792114e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.70953445e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.679944e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.65011307e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.62005859e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.58979965e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.55935379e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.46708115e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.37379456e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.34256104e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.27999992e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.24870972e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.21743874e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.18620506e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.155028e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.12392609e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.09291862e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.06202347e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.03125961e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.0006459e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '9.70200195e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '9.39941025e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '9.0988678e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '8.80055695e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '8.5046524e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '8.21133575e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '7.92078705e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '7.63317261e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '7.34867096e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '7.067453e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '6.7896904e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '6.51554718e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '6.24518814e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.97877998e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.71647873e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.45844345e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.20483398e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.95579681e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.71148415e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.47204475e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.23762321e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.00835686e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '3.78438721e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '3.56584969e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '3.35287247e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '3.1455883e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.94411697e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.74858246e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.55910339e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.37579212e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.19876041e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.02811451e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.86396103e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.70639114e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.55550356e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.41138945e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.27413549e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.14382448e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.02053404e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '9.04342365e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '7.95313263e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '6.93515205e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.99010515e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.11854553e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.32100677e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '3.59796619e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.9498806e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.37709928e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.87999475e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.45885575e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.11394823e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '8.45462263e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '6.53580189e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.38400769e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.0e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '8.45469832e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.45886338e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '3.59798145e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.32102203e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.11856079e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.99012041e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.02053709e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.14382677e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.27413855e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.4113925e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.02811832e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.19876423e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.37579594e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.74858322e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '3.35287476e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '3.56585159e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '3.78439178e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.47204704e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.7114872e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.9557991e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.20483665e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.45844879e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '6.24519043e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '6.51554947e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '6.78969345e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '7.06745911e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '7.3486763e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '8.21133881e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '8.50465546e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '8.80056e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '9.0988739e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '9.39941635e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.00064598e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.03125992e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.06202377e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.09291893e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.12392677e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.15502869e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.18620514e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.21743881e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.24871002e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.0e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
static const uint8_t PROGMEM _gammaTable[] = { _G3_ _G3_ _G3_ _G3_ }; // 256
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.00141084e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.00855505e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.02454996e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.05186737e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.09265244e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.14884353e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.222224e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.31446338e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.42713642e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.5617404e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.7197088e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.90241671e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.11119032e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.34731352e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.61203027e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.90654874e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.23204553e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.58966982e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.98054218e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.40575814e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.86639357e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.36349809e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.89810646e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.04712307e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.10838687e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.17369998e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.24315882e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.31685829e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.39489198e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.47735214e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.56432974e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.65591466e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.75219536e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.85325933e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.95919311e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.07008219e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.18601084e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.30706263e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.43332052e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.56486583e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.70177984e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.84414244e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.992033e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.1455307e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.3047123e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.46965599e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.64043808e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.81713414e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.99981928e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.18856812e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.3834548e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.58455229e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.79193449e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.00567198e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.22583723e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.45250177e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.68573618e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.92560959e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.17219305e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.42555475e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.68576431e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.95288849e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.22699642e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.5081563e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.79643202e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.09189224e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.39460373e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.7046299e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.02203846e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.34689236e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.67925644e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.00191965e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.03667755e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.07220564e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.1085103e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.14559774e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.18347435e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.22214622e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.26161938e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.30190039e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.34299498e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.38490953e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.42764978e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.47122202e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.51563215e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.56088619e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.60699005e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.65394955e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.70177078e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.75045948e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.80002155e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.85046272e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.9017889e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.95400543e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.00711861e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.06113377e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.11605682e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.17189331e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.22864895e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.28632927e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.34493999e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.40448647e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.4649744e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.52640934e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.58879681e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.65214214e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.71645088e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.78172855e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.84798031e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.91521187e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.98342857e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.05263557e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.12283821e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.19404221e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.26625252e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.33947449e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.41371307e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.48897476e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.56526337e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.64258461e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.72094345e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.80034561e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.88079605e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.96229973e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.04486198e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.12848778e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.21318207e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.29895096e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.38579788e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.47372894e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.56274872e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.65286293e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.74407539e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.83639221e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.92981796e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.02435722e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.12001495e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.21679726e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.31470795e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.41375198e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.51393471e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.61526031e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.71773453e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.82136154e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.92614594e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.03209381e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.1392086e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.24749603e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.35695992e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.46760635e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.57943878e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.69246216e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.80668182e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.92210312e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.03872833e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.15656509e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.27561569e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.39588623e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.51738052e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.64010391e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.76406021e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.88925552e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.0156929e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.14337692e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.27231369e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.40250549e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.53395996e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.66667862e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.80066757e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.9359314e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.07247467e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.21030045e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.34941483e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.48982239e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.63152618e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.77453156e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.91884308e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.00644653e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.02114021e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.03596588e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.05092384e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.06601463e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.08123863e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.09659637e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.11208824e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.12771469e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.1434761e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.15937294e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.17540573e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.19157478e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.20788055e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.2243235e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.24090408e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.2576226e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.27447968e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.29147552e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.30861084e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.32588577e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.34330078e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.36085648e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.37855316e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.39639145e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.41437134e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.43249359e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.45075851e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.46916656e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.48771835e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.50641373e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.52525375e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.54423843e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.56336823e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.58264389e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.60206543e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.62163345e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.64134811e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.66121033e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.68121994e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.70137787e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.72168427e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.74213959e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.76274399e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.78349838e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.80440277e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.82545776e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.84666351e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.86802063e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.88952957e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.91119064e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.9330043e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.9549707e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.97709061e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.99936432e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.02179214e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.04437424e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.06711166e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.09000427e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.11305252e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.13625702e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.15961777e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.18313583e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.20681107e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.23064377e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.25463486e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.27878433e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.30309265e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.32756027e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.3521875e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.37697479e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.40192261e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.42703125e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.45230087e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.47773239e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.50332581e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.52908142e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.555e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
Ошибка компиляции для платы Arduino/Genuino Mega or Mega 2560.
Этот отчёт будет иметь больше информации с
включенной опцией Файл -> Настройки ->
'Показать подробный вывод во время компиляции'
(экран не покупал)Хочу печатать через провод.
подскажите что делать ?
большое спасибо
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Плата:'Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)'
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Speaker.cpp: In member function 'void Adafruit_CPlay_Speaker::playSound(const uint8_t*, uint32_t, uint16_t, boolean)':
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Speaker.cpp:93:5: error: 'PLLFRQ' was not declared in this scope
PLLFRQ = (PLLFRQ & 0xCF) | 0x30; // Route PLL to async clk
In file included from c:program fileswindowsappsarduinollc.arduinoide_1.8.21.0_x86__mdqgnx93n4wtthardware oolsavravrincludeavrio.h:99:0,
from c:program fileswindowsappsarduinollc.arduinoide_1.8.21.0_x86__mdqgnx93n4wtthardware oolsavravrincludeavrpgmspace.h:90,
from C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtthardwarearduinoavrcoresarduino/Arduino.h:28,
from C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Speaker.cpp:4:
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Speaker.cpp:94:33: error: 'PWM4A' was not declared in this scope
TCCR4A = _BV(COM4A0) | _BV(PWM4A); // Clear on match, PWMA on
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Speaker.cpp:95:19: error: 'PWM4X' was not declared in this scope
TCCR4B = _BV(PWM4X) |_BV(CS40); // PWM invert, 1:1 prescale
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Speaker.cpp:96:5: error: 'TCCR4D' was not declared in this scope
TCCR4D = 0; // Fast PWM mode
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Speaker.cpp:97:5: error: 'TCCR4E' was not declared in this scope
TCCR4E = 0; // Not enhanced mode
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Speaker.cpp:98:5: error: 'TC4H' was not declared in this scope
TC4H = 0; // Not 10-bit mode
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Speaker.cpp:99:5: error: 'DT4' was not declared in this scope
DT4 = 0; // No dead time
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Mic.cpp: In member function 'void Adafruit_CPlay_Mic::capture(int16_t*, uint16_t)':
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_Mic.cpp:68:37: error: 'analogPinToChannel' was not declared in this scope
channel = analogPinToChannel(4); // Pin A4 to ADC channel
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:344:3: error: #error 'CPU SPEED NOT SUPPORTED'
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.28e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
static const uint8_t PROGMEM _sineTable[] = { _S3_ _S3_ _S3_ _S3_ }; // 256
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.31129013e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.34256134e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.37379471e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.40497177e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.43607361e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.4670813e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.49797638e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.52874008e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.55935394e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.5897998e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.62005875e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.65011292e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.67994415e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.70953461e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.73886612e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.76792145e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.79668274e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.82513275e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.85325439e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.88103073e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.90844528e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.93548096e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.96212204e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.98835205e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.01415558e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.0395166e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.06442032e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.08885147e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.11279541e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.13623764e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
exit status 1
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.15916428e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.18156128e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.20341507e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.22471283e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.24544128e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.26558838e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.2851416e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.30408951e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.3224205e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.34012375e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.35718842e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.37360413e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.38936081e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.40444962e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.41886093e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.43258636e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.44561752e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.45794632e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.46956589e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.4804686e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.4906485e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.50009903e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.50881454e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.51678986e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.52402008e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.5305014e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.53622894e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.5412001e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.54541138e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.54886047e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.55154526e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.5534642e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.55461609e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.555e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.53050125e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.50009888e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.44561737e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.38936096e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.37360397e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.35718826e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.3401236e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.28514145e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.22471268e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.20341492e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.15916412e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.13623749e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.08885132e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.06442017e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.0395163e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.01415543e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.9883519e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.96212173e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.90844513e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.85325455e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.79668259e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.76792114e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.70953445e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.679944e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.65011307e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.62005859e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.58979965e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.55935379e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.46708115e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.37379456e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.34256104e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.27999992e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.24870972e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.21743874e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.18620506e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.155028e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.12392609e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.09291862e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.06202347e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.03125961e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.0006459e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '9.70200195e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '9.39941025e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '9.0988678e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '8.80055695e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '8.5046524e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '8.21133575e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '7.92078705e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '7.63317261e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '7.34867096e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '7.067453e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '6.7896904e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '6.51554718e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '6.24518814e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.97877998e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.71647873e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.45844345e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.20483398e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.95579681e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.71148415e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.47204475e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.23762321e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.00835686e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '3.78438721e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '3.56584969e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '3.35287247e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '3.1455883e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.94411697e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.74858246e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.55910339e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.37579212e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.19876041e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.02811451e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.86396103e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.70639114e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.55550356e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.41138945e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.27413549e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.14382448e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.02053404e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '9.04342365e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '7.95313263e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '6.93515205e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.99010515e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.11854553e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.32100677e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '3.59796619e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.9498806e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.37709928e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.87999475e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.45885575e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.11394823e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '8.45462263e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '6.53580189e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.38400769e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.0e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '8.45469832e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.45886338e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '3.59798145e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.32102203e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.11856079e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.99012041e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.02053709e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.14382677e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.27413855e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.4113925e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.02811832e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.19876423e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.37579594e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '2.74858322e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '3.35287476e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '3.56585159e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '3.78439178e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.47204704e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.7114872e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '4.9557991e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.20483665e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '5.45844879e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '6.24519043e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '6.51554947e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '6.78969345e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '7.06745911e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '7.3486763e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '8.21133881e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '8.50465546e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '8.80056e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '9.0988739e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '9.39941635e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.00064598e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.03125992e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.06202377e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.09291893e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.12392677e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.15502869e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.18620514e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.21743881e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:718:67: warning: narrowing conversion of '1.24871002e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.0e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
static const uint8_t PROGMEM _gammaTable[] = { _G3_ _G3_ _G3_ _G3_ }; // 256
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.00141084e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.00855505e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.02454996e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.05186737e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.09265244e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.14884353e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.222224e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.31446338e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.42713642e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.5617404e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.7197088e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.90241671e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.11119032e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.34731352e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.61203027e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.90654874e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.23204553e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.58966982e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.98054218e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.40575814e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.86639357e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.36349809e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.89810646e-1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.04712307e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.10838687e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.17369998e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.24315882e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.31685829e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.39489198e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.47735214e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.56432974e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.65591466e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.75219536e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.85325933e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.95919311e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.07008219e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.18601084e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.30706263e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.43332052e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.56486583e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.70177984e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.84414244e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.992033e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.1455307e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.3047123e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.46965599e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.64043808e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.81713414e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.99981928e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.18856812e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.3834548e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.58455229e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.79193449e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.00567198e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.22583723e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.45250177e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.68573618e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.92560959e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.17219305e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.42555475e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.68576431e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.95288849e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.22699642e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.5081563e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.79643202e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.09189224e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.39460373e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.7046299e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.02203846e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.34689236e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.67925644e+0' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.00191965e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.03667755e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.07220564e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.1085103e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.14559774e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.18347435e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.22214622e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.26161938e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.30190039e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.34299498e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.38490953e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.42764978e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.47122202e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.51563215e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.56088619e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.60699005e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.65394955e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.70177078e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.75045948e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.80002155e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.85046272e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.9017889e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.95400543e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.00711861e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.06113377e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.11605682e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.17189331e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.22864895e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.28632927e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.34493999e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.40448647e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.4649744e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.52640934e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.58879681e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.65214214e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.71645088e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.78172855e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.84798031e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.91521187e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.98342857e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.05263557e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.12283821e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.19404221e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.26625252e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.33947449e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.41371307e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.48897476e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.56526337e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.64258461e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.72094345e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.80034561e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.88079605e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '3.96229973e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.04486198e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.12848778e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.21318207e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.29895096e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.38579788e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.47372894e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.56274872e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.65286293e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.74407539e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.83639221e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '4.92981796e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.02435722e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.12001495e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.21679726e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.31470795e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.41375198e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.51393471e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.61526031e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.71773453e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.82136154e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '5.92614594e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.03209381e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.1392086e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.24749603e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.35695992e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.46760635e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.57943878e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.69246216e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.80668182e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '6.92210312e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.03872833e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.15656509e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.27561569e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.39588623e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.51738052e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.64010391e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.76406021e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '7.88925552e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.0156929e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.14337692e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.27231369e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.40250549e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.53395996e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.66667862e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.80066757e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '8.9359314e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.07247467e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.21030045e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.34941483e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.48982239e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.63152618e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.77453156e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '9.91884308e+1' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.00644653e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.02114021e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.03596588e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.05092384e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.06601463e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.08123863e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.09659637e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.11208824e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.12771469e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.1434761e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.15937294e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.17540573e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.19157478e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.20788055e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.2243235e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.24090408e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.2576226e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.27447968e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.29147552e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.30861084e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.32588577e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.34330078e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.36085648e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.37855316e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.39639145e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.41437134e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.43249359e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.45075851e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.46916656e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.48771835e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.50641373e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.52525375e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.54423843e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.56336823e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.58264389e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.60206543e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.62163345e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.64134811e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.66121033e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.68121994e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.70137787e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.72168427e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.74213959e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.76274399e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.78349838e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.80440277e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.82545776e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.84666351e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.86802063e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.88952957e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.91119064e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.9330043e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.9549707e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.97709061e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '1.99936432e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.02179214e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.04437424e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.06711166e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.09000427e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.11305252e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.13625702e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.15961777e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.18313583e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.20681107e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.23064377e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.25463486e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.27878433e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.30309265e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.32756027e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.3521875e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.37697479e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.40192261e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.42703125e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.45230087e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.47773239e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.50332581e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.52908142e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
C:Program FilesWindowsAppsArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wttlibrariesAdafruit_Circuit_PlaygroundutilityAdafruit_CPlay_NeoPixel.cpp:726:68: warning: narrowing conversion of '2.555e+2' from 'double' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
Ошибка компиляции для платы Arduino/Genuino Mega or Mega 2560.
Этот отчёт будет иметь больше информации с
включенной опцией Файл -> Настройки ->
'Показать подробный вывод во время компиляции'
3D печать светильников
Шестерня vs зубчатое колесо
Недавн...
Недавн...
Приветствую! Приобрел себ...
