Linear Advance, Repetier, k-factor настройка остутствие результата
digiTALker
3961
14
Ramps 1.4
Боуден с редуктором.
Прошивка репитиер.
#define EXT0_ADVANCE_K 1
#define EXT0_ADVANCE_L 1
пробовал и 0.001 как в статье Начальный кусок кода:
; Settings Printer:
; Filament Diameter = 1.75 mm
; Nozzle Diameter = 0.8 mm
; Nozzle Temperature = 250 °C
; Bed Temperature = 100 °C
; Retraction Distance = 3 mm
; Layer Height = 0.2 mm
; Z-axis Offset = 0 mm
; Settings Print Bed:
; Bed Shape = Rect
; Bed Size X = 200 mm
; Bed Size Y = 110 mm
; Origin Bed Center = false
; Settings Speed:
; Slow Printing Speed = 1200 mm/min
; Fast Printing Speed = 4200 mm/min
; Movement Speed = 7200 mm/min
; Retract Speed = 2700 mm/min
; Printing Acceleration = 500 mm/s^2
; Jerk X-axis = firmware default
; Jerk Y-axis = firmware default
; Jerk Z-axis = firmware default
; Jerk Extruder = firmware default
; Settings Pattern:
; Linear Advance Version = 1.5
; Starting Value Factor = 10
; Ending Value Factor = 170
; Factor Stepping = 10
; Test Line Spacing = 5 mm
; Test Line Length Slow = 30 mm
; Test Line Length Fast = 60 mm
; Print Pattern = Standard
; Print Frame = true
; Number Lines = false
; Print Size X = 130 mm
; Print Size Y = 105 mm
; Print Rotation = 0 degree
; Settings Advance:
; Nozzle / Line Ratio = 1.2
; Bed leveling = 0
; Use FWRETRACT = false
; Extrusion Multiplier = 1
; Prime Nozzle = true
; Prime Extrusion Multiplier = 1
; Prime Speed = 2400
; Dwell Time = 2 s
; prepare printing
M104 S250 ; set nozzle temperature but do not wait
M190 S100 ; set bed temperature and wait
M109 S250 ; block waiting for nozzle temp
G28 ; home all axes with heated bed
G21 ; set units to millimeters
M204 P500 ; set acceleration
G90 ; use absolute coordinates
M83 ; use relative distances for extrusion
G92 E0 ; reset extruder distance
G1 X100 Y55 F7200 ; move to start
G1 Z0.2 F1200 ; move to layer height
; start the Test pattern
G4 P2000 ; Pause (dwell) for 2 seconds
G1 X45 Y2.5 F7200 ; move to start
M233 Y10 ; set K-factor
G1 E3 F2700 ; un-retract
G1 X75 Y2.5 E2.3947 F1200 ; print line
G1 X135 Y2.5 E4.7895 F4200 ; print line
G1 X165 Y2.5 E2.3947 F1200 ; print line
G1 E-3 F2700 ; retract
G1 X45 Y7.5 F7200 ; move to start
M233 Y20 ; set K-factor
G1 X75 Y7.5 E2.3947 F1200 ; print line
G1 X135 Y7.5 E4.7895 F4200 ; print line
G1 X165 Y7.5 E2.3947 F1200 ; print line
G1 X45 Y12.5 F7200 ; move to start
Вообще линейные значения Y пробовал от нуля до 90000. Как видно на фото
нет никаких изменений.
Пробовал делать M233 X1 Yзначения
Тоже никаких результатов.
Читал у буржуев, что могут быть ограничения в 12герц на шаговик. Но вряд ли это про меня, так как на откатах скорость значительно выше чем на линиях.
Создал вопрос, так как в ветке на которую ссылался выше, живых нет.
В инете куча однотипных статей, но никто не реагирует на комменты, словно откопипастили и забыли.
Взываю к вам. 4 дня не могу сдвинуться с места.
Скажите куда бы вы начали копать при моих исходных данных?
Генератор кода марлиновский, может они изменили и я пропустил какую команду?
Пробовал и обнулять через M232 в начале кода.
