Добрый день помогите со скетчем пож
folkar02
730
Добрый день,помогите пожайлусто разобратся со скетчем,при попытке поменять дисплей на REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CORNTROLLE вылетают ошибки разного образца,библиотека подключена вот сам скетч:
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
/*Notes for to dos
* Basic motion control - complete
* Come up with right settings steps/mm, acceleration, and feed rate to get good behavior - complete
* Allow motion to be turned on/off via LCD - complete
* Figure our why motors pulse - complete was resetting failure
* Figure out why motors miss steps (add heating fins?) - complete
* Calibrate the extruder in RPM - complete
* calibrate the puller in mm based on urethane wheel diameter - complete
* Add the control for two motors - complete
* link the motor velocities so that the puller motor is a percentage of the extruder RPM - complete
* Winder speed can't be changed while running - works for 'control' menu but not 'tuning' menu - complete
* Still getting Card Removed at turn on only. - complete
* Display items
* Show more on the main display (length, rpm, diameter) - complete
* Trem went blank, but returned - check why this might be - occurs when not collecting stats (like when paused)
* Remove dmin and dmax since does not seem useful - complete
* Add one more digit to M2 RPM (0.00) - complete
* Would like to change the total mm while running. - you can do this already - moved to better menus - complete
* Need to clear the Tela time stat with the length stat - complete
* Figure out how to resent the display periodically so that it restarts after static elect. - complete
* display filament diameter every 5 seconds rather than 1 second
* Temp control
* figure out the right thermister - complete
* seems to hit max or min temp - fixed
* tune the PID - complete
* add autotune to the menus - complete
* Filament width
* Add input and code for filament width sensor - complete
* add an input for turning the extruder motor on/off - complete
* get PID to work with the filament width to puller speed control and add LCD manual/automatic control - complete
* add filament dia max,min, avg, and some way to clear and freeze it - complete
* add winder on/off control with an input, screen way, and #define to enable/disable in code - complete
* make sure new configuration items are saved in flash - complete
* add new g-codes for manual/automatic control to allow it to be controlled via pronterface
* clean-up of LCD menus - complete
* need to make filament pid not time based but mm based - complete
* change back to direct control, not incremental. - complete
* add menus to change PID parameters for Filament - complete
* Clear Stats did not zero out the L (length). - complete
* Need to be able to adjust the M2 rpm same as M1. - complete
* Clean up the multiplication factors - complete
* Clean up the Tune menu to remove factors no longer needed - complete
* Change the feedmultiply to an absolute puller_feedrate - complete
* Info page does not show M2 rpm. - complete
* Need docs of each function in the menus. - complete
* make PID autotune go back to the info screen after launching
* Remove endstop logic out of the stepper interrupt ISR(TIMER1_COMPA_vect) to improve stepper speed and reliability - complete
* Rename to Mackerel from Marlin where referred to in code - complete
debug notes:
- Hardcoded the temperature reading of the extruder for testing - search for FMMDEBUGTEMP
- Change how milimeters is calculated in the planner - search for FMMDEBUGMMPLAN
15
// This configuration file contains the basic settings.
// Advanced settings can be found in Configuration_adv.h
// BASIC SETTINGS: select your board type, temperature sensor type, axis scaling, and endstop configuration
//============================= DELTA Printer ===============================
// For a Delta printer replace the configuration files with the files in the
// example_configurations/delta directory.
// User-specified version info of this build to display in [Pronterface, etc] terminal window during
// startup. Implementation of an idea by Prof Braino to inform user that any changes made to this
// build by the user have been successfully uploaded into firmware.
#define STRING_VERSION_CONFIG_H __DATE__ " " __TIME__ // build date and time
#define STRING_CONFIG_H_AUTHOR "(none, default config)" // Who made the changes.
// SERIAL_PORT selects which serial port should be used for communication with the host.
// This allows the connection of wireless adapters (for instance) to non-default port pins.
// Serial port 0 is still used by the Arduino bootloader regardless of this setting.
#define SERIAL_PORT 0
// This determines the communication speed of the printer
#define BAUDRATE 250000
// This enables the serial port associated to the Bluetooth interface
//#define BTENABLED // Enable BT interface on AT90USB devices
//// The following define selects which electronics board you have. Please choose the one that matches your setup
// 10 = Gen7 custom (Alfons3 Version) "https://github.com/Alfons3/Generation_7_Electronics"
// 11 = Gen7 v1.1, v1.2 = 11
// 12 = Gen7 v1.3
// 13 = Gen7 v1.4
// 2 = Cheaptronic v1.0
// 20 = Sethi 3D_1
// 3 = MEGA/RAMPS up to 1.2 = 3
// 33 = RAMPS 1.3 / 1.4 (Power outputs: Extruder, Fan, Bed)
// 34 = RAMPS 1.3 / 1.4 (Power outputs: Extruder0, Extruder1, Bed)
// 35 = RAMPS 1.3 / 1.4 (Power outputs: Extruder, Fan, Fan)
// 4 = Duemilanove w/ ATMega328P pin assignment
// 5 = Gen6
// 51 = Gen6 deluxe
// 6 = Sanguinololu REMEMBER TO INSTALL U8glib to your ARDUINO library folder: http://code.google.com/p/u8glib/wiki/u8glib
//#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CORNTROLLE
// The RepRapWorld REPRAPWORLD_KEYPAD v1.1
// http://reprapworld.com/?products_details&products_id=202&cPath=1591_1626
//#define REPRAPWORLD_KEYPAD
//#define REPRAPWORLD_KEYPAD_MOVE_STEP 10.0 // how much should be moved when a key is pressed, eg 10.0 means 10mm per click
// The Elefu RA Board Control Panel
// http://www.elefu.com/index.php?route=product/product&product_id=53
// REMEMBER TO INSTALL LiquidCrystal_I2C.h in your ARUDINO library folder: https://github.com/kiyoshigawa/LiquidCrystal_I2C
//#define RA_CONTROL_PANEL
//automatic expansion
#if defined (MAKRPANEL)
 #define DOGLCD
 #define SDSUPPORT
 #define ULTIPANEL
 #define NEWPANEL
 #define DEFAULT_LCD_CONTRAST 17
#endif
#if defined (REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER)
 #define DOGLCD
 #define U8GLIB_ST7920
 #define REPRAP_DISCOUNT_SMART_CONTROLLER
#endif
#if defined(ULTIMAKERCONTROLLER) || defined(REPRAP_DISCOUNT_SMART_CONTROLLER) || defined(G3D_PANEL)
 #define ULTIPANEL
 #define NEWPANEL
#endif
#if defined(REPRAPWORLD_KEYPAD)
  #define NEWPANEL
  #define ULTIPANEL
#endif
#if defined(RA_CONTROL_PANEL)
 #define ULTIPANEL
 #define NEWPANEL
 #define LCD_I2C_TYPE_PCA8574
 #define LCD_I2C_ADDRESS 0x27 // I2C Address of the port expander
#endif
//I2C PANELS
//#define LCD_I2C_SAINSMART_YWROBOT
#ifdef LCD_I2C_SAINSMART_YWROBOT
  // This uses the LiquidCrystal_I2C library ( https://bitbucket.org/fmalpartida/new-liquidcrystal/wiki/Home )
  // Make sure it is placed in the Arduino libraries directory.
  #define LCD_I2C_TYPE_PCF8575
  #define NEWPANEL
  #define ULTIPANEL
#endif
// PANELOLU2 LCD with status LEDs, separate encoder and click inputs
//#define LCD_I2C_PANELOLU2
#ifdef LCD_I2C_PANELOLU2
  // This uses the LiquidTWI2 library v1.2.3 or later ( https://github.com/lincomatic/LiquidTWI2 )
  // Make sure the LiquidTWI2 directory is placed in the Arduino or Sketchbook libraries subdirectory.
  // (v1.2.3 no longer requires you to define PANELOLU in the LiquidTWI2.h library header file)
  // Note: The PANELOLU2 encoder click input can either be directly connected to a pin
  // (if BTN_ENC defined to != -1) or read through I2C (when BTN_ENC == -1).
  #define LCD_I2C_TYPE_MCP23017
  #define LCD_I2C_ADDRESS 0x20 // I2C Address of the port expander
  #define LCD_USE_I2C_BUZZER //comment out to disable buzzer on LCD
  #define NEWPANEL
  #define ULTIPANEL
  #ifndef ENCODER_PULSES_PER_STEP
 #define ENCODER_PULSES_PER_STEP 4
  #endif
  #ifndef ENCODER_STEPS_PER_MENU_ITEM
 #define ENCODER_STEPS_PER_MENU_ITEM 1
  #endif
  #ifdef LCD_USE_I2C_BUZZER
 #define LCD_FEEDBACK_FREQUENCY_HZ 1000
 #define LCD_FEEDBACK_FREQUENCY_DURATION_MS 100
  #endif
#endif
// Panucatt VIKI LCD with status LEDs, integrated click & L/R/U/P buttons, separate encoder inputs
//#define LCD_I2C_VIKI
#ifdef LCD_I2C_VIKI
  // Note: The pause/stop/resume LCD button pin should be connected to the Arduino
  // BTN_ENC pin (or set BTN_ENC to -1 if not used)
  #define LCD_USE_I2C_BUZZER //comment out to disable buzzer on LCD (requires LiquidTWI2 v1.2.3 or later)
  #define NEWPANEL
  #define ULTIPANEL
#endif
// Shift register panels
// 2 wire Non-latching LCD SR from:
// https://bitbucket.org/fmalpartida/new-liquidcrystal/wiki/schematics#!shiftregister-connection
//#define SR_LCD
#ifdef SR_LCD
   #define SR_LCD_2W_NL // Non latching 2 wire shift register
   //#define NEWPANEL
#endif
#ifdef ULTIPANEL
// #define NEWPANEL //enable this if you have a click-encoder panel
 #define SDSUPPORT
  #define ULTRA_LCD
  #ifdef DOGLCD // Change number of lines to match the DOG graphic display
    #define LCD_WIDTH 20
    #define LCD_HEIGHT 5
  #else
    #define LCD_HEIGHT 4
  #endif
#else //no panel but just LCD
  #ifdef ULTRA_LCD
  #ifdef DOGLCD // Change number of lines to match the 128x64 graphics display
  #else
    #define LCD_WIDTH 16
    #define LCD_HEIGHT 2
  #endif
  #endif
#endif
// default LCD contrast for dogm-like LCD displays
#ifdef DOGLCD
# ifndef DEFAULT_LCD_CONTRAST
# define DEFAULT_LCD_CONTRAST 32
# endif
#endif
// Increase the FAN pwm frequency. Removes the PWM noise but increases heating in the FET/Arduino
//#define FAST_PWM_FAN
// Temperature status LEDs that display the hotend and bet temperature.
// If all hotends and bed temperature and temperature setpoint are
