Русский в TFT35 для Большого Дерева!
Граждане! Давайте поможем русификации этакого экрана. Короткие емкие названия иконок.
Для них, это как нам китайская грамота ...) Ваши предложения... пишем вместо кракозяблей в кавычках ! Войдет в новою прошивку.
#define RU_LANGUAGE "Язык"
#define RU_HEAT "§±§а§Х§а§Ф§в§Ц§У"
#define RU_MOVE "§Ґ§У§Ъ§Ш§Ц§Я§Ъ§Ц"
#define RU_HOME "Домой"
#define RU_PRINT "§±§Ц§й§С§д§о"
#define RU_EXTRUDE "§ї§Ь§г§д§в§е§Щ§Ъ§с"
#define RU_FAN "§Ј§Ц§Я§д§Ъ§Э§с§д§а§в"
#define RU_SETTINGS "§µ§г§д§С§Я§а§У§Ь§С"
#define RU_LEVELING "§і§д§а§б"
#define RU_POINT_1 "Point 1"
#define RU_POINT_2 "Point 2"
#define RU_POINT_3 "Point 3"
#define RU_POINT_4 "Point 4"
#define RU_ABL "§і§д§а§б"
#define RU_INC "§µ§У§Ц§Э§Ъ§й§Ъ§д§о"
#define RU_DEC "§µ§Ю§Ц§Я§о§к§Ъ§д§о"
#define RU_NOZZLE "§і§а§б§Э§а"
#define RU_BED "§±§а§Х.§і§д§а§Э§С"
#define RU_STOP "§¬§С§Э§Ъ§Т§в."
#define RU_BACK "§Ј§а§Щ§У§в§С§д"
#define RU_PAGE_UP "§Ї§С§Щ§С§Х"
#define RU_PAGE_DOWN "§Ј§б§Ц§в§Ц§Х"
#define RU_PAUSE "§±§С§е§Щ§С"
#define RU_RESUME "§±§в§а§Х§а§Э§Ш§Ъ§д§о"
#define RU_LOAD "§©§С§Ф§в§е§Щ§Ь§С"
#define RU_UNLOAD "§Ј§н§Ф§в§е§Щ§Ь§С"
#define RU_SLOW_SPEED "§®§Ц§Х§Э§Ц§Я§Я§а"
#define RU_NORMAL_SPEED "§Ї§а§в§Ю§С§Э§о§Я§а"
#define RU_FAST_SPEED "§ў§н§г§д§в§а"
#define RU_FAN_FULL_SPEED "§®§С§Ь§г§Ъ§Ю§е§Ю"
#define RU_FAN_HALF_SPEED "§і§в§Ц§Х§Я§с§с §г§Ь."
#define RU_ROTATE_UI "Rotate UI"
#define RU_TOUCHSCREEN_ADJUST "§¬§С§Э§Ъ§Т§в§а§У§Ь§С"
#define RU_MORESETTING "§Т§а§Э§о§к§Ц §Ї§С§г§д§в§а§Ы§Ь§Ъ"
#define RU_SCREEN_INFO "§Є§Я§ж§а"
#define RU_WHITE "§Т§Ц§Э§н§Ы"
#define RU_BLACK "§й§Ч§в§Я§н§Ы"
#define RU_BLUE "§г§Ъ§Я§Ъ§Ы"
#define RU_RED "§Ь§в§С§г§Я§н§Ы"
#define RU_GREEN "§Щ§Ц§Э§Ц§Я§н§Ы"
#define RU_CYAN "§г§Ъ§Я§Ъ§Ы"
#define RU_YELLOW "§Ш§Ч§Э§д§н§Ы"
#define RU_BROWN "§Ь§а§в§Ъ§й§Я§Ц§У§н§Ы"
#define RU_GRAY "§г§Ц§в§н§Ы"
#define RU_DISCONNECT "Disconnect"
#define RU_BAUDRATE_115200 "115200"
#define RU_BAUDRATE_250000 "250000"
#define RU_RUNOUT_OFF "Runout OFF"
#define RU_RUNOUT_ON "Runout ON"
#define RU_PERCENTAGE "Percentage"
#define RU_BABYSTEP "§®§Ъ§Ь§в§а§к§С§Ф Z"
#define RU_PERCENTAGE_SPEED "§і§Ь§а§в§а§г§д§о"
#define RU_PERCENTAGE_FLOW "§±§а§д§а§Ь"
#define RU_VALUE_ZERO "Zero"
#define RU_1_DEGREE "1Ўж"
#define RU_5_DEGREE "5Ўж"
#define RU_10_DEGREE "10Ўж"
#define RU_X_INC "X+"
#define RU_Y_INC "Y+"
#define RU_Z_INC "Z+"
#define RU_X_DEC "X-"
#define RU_Y_DEC "Y-"
#define RU_Z_DEC "Z-"
#define RU_X_HOME "X"
#define RU_Y_HOME "Y"
#define RU_Z_HOME "Z"
#define RU_001_MM "0.01mm"
#define RU_01_MM "0.1mm"
#define RU_1_MM "1mm"
#define RU_5_MM "5mm"
#define RU_10_MM "10mm"
#define RU_1_PERCENT "1%"
#define RU_5_PERCENT "5%"
#define RU_10_PERCENT "10%"
#define RU_READY "§¤§а§д§а§У"
#define RU_PRINTING "§±§Ц§й§С§д§С§р"
#define RU_BUSY "§і§Ъ§г§д§Ц§Ю§С §Щ§С§Я§с§д§С..."
#define RU_UNCONNECTED "§Ї§Ц§д §б§а§Х§Ь§Э.!"
#define RU_DISCONNECT_INFO "Now you can control the printer by your computer!"
#define RU_LOADING "§©§С§Ф§в§е§Щ§Ь§С..."
#define RU_POWER_FAILED "Continue printing?"
#define RU_CONTINUE "Continue"
#define RU_CANNEL "Cancel"
#define RU_ADJUST_TITLE "Touch Screen Calibration"
#define RU_ADJUST_INFO "Please click on the red dot"
#define RU_ADJUST_OK "Adjustment Success"
#define RU_ADJUST_FAILED "Adjustment failed, Please Try Again"
#define RU_WARNING "Warning"
#define RU_STOP_PRINT "Stop printing?"
#define RU_CONFIRM "Confirm"
#define RU_TFTSD "TFT SD"
#define RU_READ_TFTSD_ERROR "Read TFT SD card error!"
#define RU_TFTSD_INSERTED "Card inserted!"
#define RU_TFTSD_REMOVED "Card removed!"
#define RU_U_DISK "U Disk"
#define RU_READ_U_DISK_ERROR "Read U Disk error!"
#define RU_U_DISK_INSERTED "U Disk inserted!"
#define RU_U_DISK_REMOVED "U Disk removed!"
#define RU_ONBOARDSD "OnboardSD"
#define RU_READ_ONBOARDSD_ERROR "Read Onboard SD card error!"
#define RU_FILAMENT_RUNOUT "filament runout!"
Всем спасибо заранее.
Для пользователей Flashforge, конвертер 3MF (AD5X, 5M, 5M Pro и Creator 5).
Bambu Studio предупреждает о floating cantilever: как найти виновника делением модели по высоте
Сопла и сопли
как перемотка с калибровкой мо...
Очень интересный обзор, спасиб...
