Error: Heating failed, system stopped! Heater_ID: 0
После ~2 часов печати получаю ошибку:
Unhandled communication errorThe was an unhandled error while talking to the printer. Due to that OctoPrint disconnected. Error: Heating failed, system stopped! Heater_ID: 0
RAMPS 1.4+arduino mega, прошивка Marlin 1.1.0-RC8.
В файле Configuration_adv.h:
#if ENABLED(THERMAL_PROTECTION_HOTENDS)
#define THERMAL_PROTECTION_PERIOD 100 // Seconds
#define THERMAL_PROTECTION_HYSTERESIS 15 // Degrees Celsius
* Whenever an M104 or M109 increases the target temperature the firmware will wait for the
* WATCH_TEMP_PERIOD to expire, and if the temperature hasn't increased by WATCH_TEMP_INCREASE
* degrees, the machine is halted, requiring a hard reset. This test restarts with any M104/M109,
* but only if the current temperature is far enough below the target for a reliable test.
* If you get false positives for 'Heating failed' increase WATCH_TEMP_PERIOD and/or decrease WATCH_TEMP_INCREASE
* WATCH_TEMP_INCREASE should not be below 2.
#define WATCH_TEMP_PERIOD 25 // Seconds
#define WATCH_TEMP_INCREASE 6 // Degrees Celsius
#endif
* Thermal Protection parameters for the bed are just as above for hotends.
#if ENABLED(THERMAL_PROTECTION_BED)
#define THERMAL_PROTECTION_BED_PERIOD 100 // Seconds
#define THERMAL_PROTECTION_BED_HYSTERESIS 15 // Degrees Celsius
#endif
Работа с пластиком.
нужна консультация
тот случай, когда сканер не ну...
Ну ладно мышку под свою ладошк...
У меня гравировка на боковой ч...
Добрый день! Прочитал правила,...
Ребята приветствую! Прошу, пож...
Подскажите, есть ли смысл в не...
