CREALITY CR-10S PRO
Описание 3D-принтера «CREALITY CR-10S PRO»
MATRIX AUTOMATIC LEVELING
It would appear that the CR-10S Pro features an inductive proximity sensor, gifting the printer the ability to automatically detect the bed and assist in reading a matrix of points across the bed for bed leveling. This much is standard and well known.
The company goes on further to hint at “Compensation sensor setting”, and “Auxillary leveling”. It is not clear, but we would presume this to mean a live Z-offset to help fine tune the bed level as you print.
V2.4.1 MOTHERBOARD
The Cr-10S Pro appears to feature an upgraded version of the mainboard used in the CR-10S. It is claimed to increase the stability and reliability of the printer’s performance, but in the absence of any metrics, there’s nothing we can say to this. It is hinted that the board has TMC drivers, but not explicitly stated which drivers are present. If so, this should sum up to a quieter printer that handles vertical planes and curves with fewer “salmon skin” artifacts.
IMPORTED TEFLON TUBE
Paying heed to the Bowden extruder arrangement on the CR-10S, the CR-10S pro boasts Capricorn Teflon tubing – possibly the best option for filament feeding in this way, due to high lubricity and high-temperature resistance.
TOUCH SCREEN
Gone is the dot matrix LCD of the CR-10S, replaced by a vivid touchscreen unit and simplified UI. It very much looks to have been lifted from the CR-X. Indeed, the general arrangement of the base unit, with integrated power, mainboard and display appearing to be that of the CR-X.
Further similarities between the two come in a 300 x 300 x 400mm print volume, with a glass bed coated in an adhesive sticker.
RESUME PRINT FUNCTION
A welcome feature for those that take advantage of that large build volume comes in print resume functionality. The CR-10S Pro will be able to pick up printing from where it left off after a power cut.
The original CR-10S has an auto-resume function, so it’s business as usual here for the line.
FILAMENT DETECTION
As with the CR-10S that precedes it, the CR-10S Pro features filament runout detection – again a welcome feature on long filament guzzling prints.
DOUBLE GEAR EXTRUSION MECHANISM
One of the more exciting hardware upgrades is the addition of a Bondtech-like dual gear feed in the extruder. Such a system should result in a more reliable and stronger feed of filament into that shiny new Cap’ tube. We likey.
QUICK HEATING PRINT BED
Creality claims the CR-10S Pro’s heated bed can heat up to its max temp of 110 degrees Celsius in 5 minutes. Looking over the spec sheet, the output rating of 24V should confirm this to be the case.
BRANDED POWER SUPPLY
The documentation for the CR-10S Pro shows a Mean Well power supply, a reputable brand that’s known for the reliability and safety of their PSUs.
Beyond these nine main features, the Creality CR-10S continues the design language of the brand’s recent printers — ribbon over aviation cables, oversized bed leveling nuts. From the CR-10S, we see a dual-leadscrew setup too, which should help with stability printing in the upper range of the build volume.
* The difference bettwen CR-10 and CR-10S is CR-10S upgraded with dual Z axies lead screw rod which make printing quality better and more stable. Another upgrading is CR-10S mainboard with filament monitor function, this function can detect when filament is running out or not. Resume prints: CR-10S has the ability to resume prints even after a power outage or lapse occurs.
Популярные 3D-принтеры
1822 статей
1511 владельцев
6 предложений
от 14500 ₽
1569 статей
1715 владельцев
2 предложения
по договорной цене
1383 статей
1085 владельцев
5 предложений
от 19500 ₽
